Resizing the Trigger Icon in Dynamic Panel Widget
  • July 8, 2021
  • 3 replies
  • 1488 views
I'm looking to develop a mashup for mobile use that takes advantage of the dynamic panel widget. However, the trigger button/ icon is extremely small when used in that setting. Is there a way to enlarge the icon?
Best answer by PaiChung
I could be wrong, but I thought you could provide custom icons for that.
PaiChung22-Sapphire IAnswer
22-Sapphire I
July 12, 2021
11-Garnet
August 6, 2021
@PaiChung How to add custom icons to the Dynamic Panel trigger button?
Nate_14510-MarbleAuthor
If there is a way to do that while making that icon bigger than the default button then yes. If a custom icon ends up the same size as what the default is then it doesn't do a ton of good.
I've subverted this issue on my end by tying the expand/ collapse action to a button widget on each part of the panel that collapses/ expands to view the other panel. I then set the panels to only display at 100% minimum to take up the whole screen.
