SQL Server SELECT IF Exists Not working
  • February 7, 2020
  • 2 replies
  • 5284 views
Any idea about why SELECT IF EXISTS command is not working.
Thank You!
Naeem
Syntax is not correct. Please check this link: https://stackoverflow.com/questions/7887011/how-to-drop-a-table-if-it-exists
Hope it helps,
Raluca Edu
18-Opal
February 7, 2020
Hello Naeem,
You can't use [[abc]] as placeholders for table names, only for parameter values. It's a rather frequent question, here's another example: https://community.ptc.com/t5/ThingWorx-Developers/Problems-with-the-input-parameter-in-the-SQL-query-service/m-p/618832
Constantine
18-Opal
February 7, 2020
Just to be precise -- it is technically possible to use <<abc>>, which simply replaces strings in your SQL statement, so you can use it anywhere in your service (unlike [[abc]], which works as PreparedStatement parameters). However, this makes your service vulnerable to SQL Injection exploits (e.g. https://portswigger.net/web-security/sql-injection), so you should be very (VERY) careful with that. Make sure you only expose this service to System user and wrap it in another one, which thoroughly validates its parameters. If you don't do it -- somebody might be able to steal your credentials, drop the entire database, etc. etc.
/ Constantine
mnaeem1-VisitorAuthor
Thank You @Constantine and @raluca_edu ,
Still not able to drop the temporary table according to the link that @raluca_edu mentioned in her comment.
Moreover, according to @Constantine I'd like to avoid using query as a string.
Basically I've a query in which I'm using both DDL and DML functionality. Is there a way of implementing it.
I'd like to use the following single query which works fine, not in thingworx.
IF OBJECT_ID('tempdb..#RESULT_TABLE') IS NOT NULL DROP TABLE #RESULT_TABLE;
WITH T1 As
SELECT ............
WHERE ...............
AND ................
AND ...................
SELECT DISTINCT ..........
INTO #RESULT_TABLE
FROM .................
AND ....................
AND ..................;
WITH TO_DELETE AS
SELECT ...................
DELETE T1
FROM #RESULT_TABLE T1
INNER JOIN TO_DELETE T2 ON T1.ID  = T2.ID;
WITH valid AS
SELECT DISTINCT .............. FROM #RESULT_TABLE
SELECT SUM(Duration) tot_duration FROM valid;
Thank You!
Naeem
