Feb 14, 2017 2:51 PM UTC
Security context stack is growing large
Hi Guys,
I have quite large problem. It is few days ago when this warning start to showing up in my Application log. It is very fast filling my Application log files.
I can see that the problem is coming from WebSocket subsystem, but I cannot find from where exactly.
We are using Kepserver + IoT gateway with Websocket agents.
But it worked without problems few months until know.
Is there anyway how to trace the source?
Tomas
tcoufalAnswer
Feb 15, 2017 12:40 PM UTC
Found the problem.
I was heaving few subscriptions of DataChangeEvent and one was set on Property that I was changing in the same script. So it was stuck in a loop.
Stupid..
Luckily I was not the one who made that mistake , but it was more difficult to find.
Tomas
20-Turquoise
Feb 14, 2017 3:07 PM UTC
Do you have a connections server? Is there any other errors in the application log? What is your thingworx version?
tcoufal1-VisitorAuthor
Feb 14, 2017 3:12 PM UTC
We are not using a connection server. Version is 7.2.0.
There is only one (two) other errors in AppLog
Feb 15, 2017 10:21 AM UTC
Are the errors messages consistent with the warning messages? From the error message it seems that service is being invoked with some null data.
May 17, 2017 3:09 PM UTC
With a fresh install of TWX Postgre 7.4 (after running script DBCleanup, DBSetup, SchemaSetup), I imported some extension like Mail, Autocomplete, Logout Button.... Then, with user Administrator, create and delete Things (GenericThing) generate these warnings !
Dec 6, 2017 5:14 AM UTC
Hi Tomas,
We have a condition to terminate loop, so it should execute right, but why still it give that error?
