Mar 14, 2017 3:07 PM UTC
Thing view property value receive from Mqtt Broker but not store that in value stream
Hi All,
I need information about the following problem :
I used MQTT  extention in Thingworx (I have impoted the MQTT estention) and I created a Thing using  Thing Template MQTT.
I have configured the connection Mqtt to Broker mosquitto using serverName test.mosquitto.org
I have  developed a Mqtt published publisher.exe using  C#.
I checked the system and Thingworx has received the values published from publisher.exe.
The property value on Thingworx was defined  as STRING with persistent and logged enabled.
The property values  published from publisher.exe are visible on Thing property (by refresh) or in mashup that used GetData service (GetProperty + convert string value to number) that refresh the value every every 5 second.
When I want to look the property value using a widget  Time Series  Chart by QueryPropertyHistory I’m not found value in value stream.
The property value was received from the MQTT broker but they  are not stored in value stream, Why ?
Is needed  particularly configuration ?
Many Thanks
BR
Dimitri
Mar 14, 2017 3:24 PM UTC
Hi Dimitri! Have you checked the properties as "Logged"? It is required to push them to the Value Stream.
Mar 14, 2017 3:44 PM UTC
Hi Adam,
many thanks for your answer.
The Property of thing  have persistent and logged enabled.
BR
Dimitri
Mar 14, 2017 3:49 PM UTC
Hi Adam,
I checked the Application Monitoring and I received the following message (I think for any value received from Broker).
These message could be the reason that the value stream was not loaded ?
BR
Dimitri
Jan 22, 2018 1:40 PM UTC
Hello Dimitri,
did you find solution? I do not want parsing data. I have values from device in property view, but they can not store in Value stream. If I try make subscription on anydatachange for move values to other properties then I get also error in application log. Can anyone help me please?
TWX 8.1, local installed MosquitoBroker on 1883 and MqTT extensions 2.1.0
Error Handling Publish Arrived for [DemoThing/DoorStatus] : [null]
Jan 22, 2018 2:18 PM UTC
Hi Karel,
Please, can you send me the code of subscription to take json packet from Thing MQTT Subscribe Thing and store that into properties of Target Thing.
I'm using a Thing to manage the  MQTT Subscribe service and more Thing Target  that contains a properties and value stream.
BR
Dimitri
Jan 22, 2018 3:05 PM UTC
Thingworx has some new MQTT functionality in the 8.2 release. I think that it would be worth upgrading and testing with that version before putting too much energy into work-arounds.
Apr 17, 2018 10:17 PM UTC
Hi dbologna,
Did you solve this problem?
