Aug 28, 2019 6:51 PM UTC
Thingworx 8.4 Trial Warning: Problem running post-install step. Installation may not complete Ubuntu
Following the steps in this guide I was able to get the installer to run, but it's failing.  Error message is not of much help.  Following some forum recommendations I uninstalled and reinstalled the OS.  i.e. new VM.  Running Ubuntu 18.04 on an Azure F4 VM.
It appears to be similar to this unsolved windows 7 issue, which was asking for some logs, I attached the install.log in case that is relevant
Any thoughts on what to try next?
Configuration Summary
Review and confirm the following configuration settings:
Installation directory: /opt/ThingWorxH2Trial-8.4.0-SNAPSHOT
Local ThingWorx port: 8080
Local ThingWorx SSL port: 443
Minimum Java heap size for ThingWorx: 1024
Maximum Java heap size for ThingWorx: 2048
Press [Enter] to continue:
Setup is ready to install ThingWorx Trial for H2.
Do you want to continue? [Y/n]: Y
Setup is installing ThingWorx Trial for H2. This might take a few minutes.
 0% ______________ 50% ______________ 100%
 ########################################Warning: Problem running post-install step. Installation may not complete
correctly
 Error running ./check-http-response --username "Administrator" --password ****
--hostname "localhost" --hostport "443" --useSSL=1: 1
correctly
 Error occured while running postInstall Validation scripts
ThingWorx Trial for H2 installation failed.
Error: There has been an error.
Sep 16, 2019 3:48 PM UTC
I used a Windows server and was able to get ThingWorx running.  I have not tried the manual instructions.
Aug 29, 2019 8:06 AM UTC
Hi @mikefinch87
I checked the attached install logs and looks like the issue is due to insufficient rights. Please check this article for more information.
Vibhuti
Aug 30, 2019 8:33 PM UTC
I tried a fresh install of jdk 1.8.0u221 following the instructions here.  Same  results:
correctly
correctly
Thoughts on how to get this to run on Ubuntu
Sep 2, 2019 8:53 AM UTC
@mikefinch87  Please check this post,hope this is helpful.
