Thingworx Application is down frequently?
  • July 8, 2019
  • 6 replies
  • 3143 views
Thingworx Application is down frequently , It is taking very long time to respond.
This my Thingworx Application Log File
2019-07-08 14:47:00.161+0530 [L: WARN] [O: c.m.v.c.i.NewPooledConnection] [I: ] [U: ] [S: ] [T: pool-24-thread-1] [c3p0] A PooledConnection that has already signalled a Connection error is still in use!
2019-07-08 14:47:00.161+0530 [L: WARN] [O: c.m.v.c.i.NewPooledConnection] [I: ] [U: ] [S: ] [T: pool-24-thread-1] [c3p0] Another error has occurred [ org.postgresql.util.PSQLException: This connection has been closed. ] which will not be reported to listeners!
2019-07-08 14:47:00.161+0530 [L: ERROR] [O: c.t.p.p.PostgresModelExceptionTranslator] [I: ] [U: ] [S: ] [T: pool-24-thread-1] [message: [2,002] No connection. Contact the administrator.]
2019-07-08 14:47:00.161+0530 [L: WARN] [O: c.t.s.s.f.e.ReservationReclaimer] [I: ] [U: ] [S: ] [T: pool-24-thread-1] Failed to get any reservations
2019-07-08 14:52:09.654+0530 [L: ERROR] [O: E.c.t.w.Things] [I: ] [U: Orissa_HT_API] [S: ] [T: http-nio-8080-exec-20] [message: java.io.IOException: An existing connection was forcibly closed by the remote host]
2019-07-08 14:52:09.654+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Orissa_HT_API] [S: ] [T: http-nio-8080-exec-20] Internal error: org.apache.catalina.connector.ClientAbortException: java.io.IOException: An existing connection was forcibly closed by the remote host
2019-07-08 14:52:09.654+0530 [L: ERROR] [O: c.t.w.BaseService] [I: ] [U: Orissa_HT_API] [S: ] [T: http-nio-8080-exec-20] [context: com.thingworx.webservices.context.HttpExecutionContext@14720111][message: java.io.IOException: An existing connection was forcibly closed by the remote host]
2019-07-08 14:57:18.295+0530 [L: WARN] [O: c.m.v.c.i.NewPooledConnection] [I: ] [U: ] [S: ] [T: pool-24-thread-1] [c3p0] A PooledConnection that has already signalled a Connection error is still in use!
2019-07-08 14:57:18.311+0530 [L: WARN] [O: c.m.v.c.i.NewPooledConnection] [I: ] [U: ] [S: ] [T: pool-24-thread-1] [c3p0] Another error has occurred [ org.postgresql.util.PSQLException: This connection has been closed. ] which will not be reported to listeners!
2019-07-08 14:57:18.311+0530 [L: ERROR] [O: c.t.p.p.PostgresModelExceptionTranslator] [I: ] [U: ] [S: ] [T: pool-24-thread-1] [message: [2,002] No connection. Contact the administrator.]
2019-07-08 14:57:18.311+0530 [L: WARN] [O: c.t.s.s.f.e.ReservationReclaimer] [I: ] [U: ] [S: ] [T: pool-24-thread-1] Failed to get any reservations
Can any give suggestion how to find root cause of server down issue and what are all possible issues are there?
Best answer by slangley
Hi @sarathi.
The logs you provided contain many significant errors which point to coding as an issue.  Here are just a few:
2019-07-15 13:31:50.920+0530 [L: WARN] [O: c.t.w.c.ThreadLocalContext] [I: ] [U: AmalanT] [S: ] [T: pool-21-thread-1] ----> Security context stack is growing large : current size = [depth: 31]
2019-07-15 13:32:52.868+0530 [L: WARN] [O: c.t.w.c.ThreadLocalContext] [I: ] [U: sarathi] [S: ] [T: pool-21-thread-1] ----> Security context stack is growing large : current size = [depth: 32]
2019-07-15 13:34:58.337+0530 [L: WARN] [O: c.t.w.c.ThreadLocalContext] [I: ] [U: bhavya.redeem] [S: ] [T: pool-21-thread-1] ----> Security context stack is growing large : current size = [depth: 33]
2019-07-15 13:38:39.056+0530 [L: WARN] [O: c.t.w.c.ThreadLocalContext] [I: ] [U: Kshitij] [S: ] [T: pool-21-thread-1] ----> Security context stack is growing large : current size = [depth: 34]
2019-07-15 13:50:40.385+0530 [L: WARN] [O: c.m.v.a.ThreadPoolAsynchronousRunner] [I: ] [U: ] [S: ] [T: C3P0PooledConnectionPoolManager[identityToken->1hge4xna31vmo9iejfbjxp|232a9884]-AdminTaskTimer] com.mchange.v2.async.ThreadPoolAsynchronousRunner$DeadlockDetector@6dc5c687 -- APPARENT DEADLOCK!!! Creating emergency threads for unassigned pending tasks!
2019-07-15 13:50:59.807+0530 [L: WARN] [O: c.m.v.a.ThreadPoolAsynchronousRunner] [I: ] [U: ] [S: ] [T: C3P0PooledConnectionPoolManager[identityToken->1hge4xna31vmo9iejfbjxp|232a9884]-AdminTaskTimer] com.mchange.v2.async.ThreadPoolAsynchronousRunner$DeadlockDetector@6dc5c687 -- APPARENT DEADLOCK!!! Complete Status: __    Managed Threads: 8__    Active Threads: 0__    Active Tasks: __    Pending Tasks: __        com.mchange.v2.resourcepool.BasicResourcePool$ScatteredAcquireTask@3888b34c__        com.mchange.v2.resourcepool.BasicResourcePool$ScatteredAcquireTask@239021f9__        com.mchange.v2.resourcepool.BasicResourcePool$ScatteredAcquireTask@3833ddd0__        com.mchange.v2.resourcepool.BasicResourcePool$ScatteredAcquireTask@5f032ce3__        com.mchange.v2.resourcepool.BasicResourcePool$ScatteredAcquireTask@22ecf69c__Pool thread stack traces:__
In regard to the "Security context growing large" error, here is an article to explain what is occurring.
For identifying the cause of the deadlocks, you would need to look at the running processes in the database at the time of the occurrence.  I recommend installing the Support Tools for assistance.
Regards.
--Sharon
Support
July 10, 2019
Hi @sarathi.
It sounds like you're losing database connectivity.  Here are some things you can check:
  • Space issues
  • Network issues or possibly a problem with the NIC (assuming the database and ThingWorx are on separate machines
You should also check the database logs for more information on what may be occurring.
Regards.
--Sharon
sarathi1-VisitorAuthor
Hi @slangley
Thanks for your information still am facing the same issue
Herewith I have attached my Postgres log file
2019-07-12 19:20:09 IST LOG: could not receive data from client: An existing connection was forcibly closed by the remote host.
2019-07-12 19:20:09 IST LOG: unexpected EOF on client connection with an open transaction
2019-07-12 19:20:09 IST LOG: could not send data to client: An existing connection was forcibly closed by the remote host.
2019-07-12 19:20:09 IST FATAL: connection to client lost
2019-07-12 20:57:20 IST ERROR: canceling autovacuum task
2019-07-12 20:57:20 IST CONTEXT: automatic vacuum of table "thingworx_29052019.public.property_vtq"
I could see that error frequently
