Thingworx Learning
Dear All,
I am from Mechanical background, Working on PTC CREO for 10 years ,  Now planning to swtich to IoT and chosen thingWorx to learn but not sure what are all the prerequisites required to start this thingworx  course?
where i can start this learnings? can i practice this course in free of cost?
and i do not have any languages experiences  , only having basic knowledge on Python,  will this little knowledge help me anywhere to learn this course?
Kindly guide me to start..
thanks
Balan M
danmorinAnswer
Hi @BM_10412602
First, it is Javascript not Java because it is different.
Second, We can't get a ThingWorx Composer here. You can have a ThingWorx Portable by following the procedure here https://github.com/ptc-iot-sharing/ThingworxPortableScripts but you will need access to PTC Support Portal and should have permission to download ThingWorx H2 as instructed.
HI @BM_10412602
You can start with learning about HTML, CSS, and Javascript anywhere on the internet. While learning you can start learning ThingWorx officially on https://trainingcentral.ptcu.com/learn if you have a ThingWorx subscription then you should be able to access that. Or you can check Udemy course https://www.udemy.com/course/iot-development-with-thingworx-by-example-2-in-1/ for a cheaper option
Best Regards
Thanks for your time and reply, Yes i can understand the HTML, JAVA and CSS,
i was checking courses in the developer portal and i saw the notification this portal will be retried in sometimes and we can get all content under PTC community, i just want to know can we get the virtual thing Worx composer to practice in PTC community?
kindly help me, please share the links if anything.
Balan M
danmorin1-VisitorAnswer
Hi @BM_10412602
