Thingworx trial Error Installation
  • June 29, 2018
  • 2 replies
  • 2676 views
I received this error while installing Thingworx trial edition
Problem running post-install step.  Integration may not complete correctly
Error running
.\installer-twxfoundationH2-devzone-windows.exe -- installdir "C:\Program Files (x86)\ThingWorxTrialEdition"
--unattendedmodeui minimal --mode unattended
--accept_eula YES --TWX_PORT 8080 --disable-components "docker_validator, docker_machine_validator": Program ended with an error exit code.
I am not sure what I need to do to fix this.
Brad
Community Manager
June 29, 2018
Hi Brad.
Are you running a 64-bit O/S?
Please review this guide for verifying that you are running a supported version.
--Sharon
BM11-VisitorAuthor
Yes, I'm running 64 bit O/S …..Windows 10 Pro
Community Manager
June 29, 2018
Hi @BM1.
Did you review the document to ensure you are adhering to all prerequisites?  Do you have another system you can try it on?
--Sharon
The trial edition is the collection of all Thingworx solutions for docker only.
You have to install it on a docker, or, install the ThingWorx Foundation only.
Community Manager
November 27, 2018
Hi @BM1.
If one of the previous responses provided a solution to your issue, please mark it as the Accepted Solution for the benefit of others who may have the same problem.
--Sharon
