Oct 27, 2017 7:51 AM UTC
Unable to connect database thing to MSSQL DB
Hi
We have installed thingworx with mssql database. We created one Thing and selected "Database" as "ThingTemplate",  now in configuration tab we have filled the options as below :
jDBCConnectionURL =  jdbc:sqlserver://localhost:1433;databaseName=thingworx;
jDBCDriverClass = com.mysql.jdbc.driver
But the connection is not getting established, the property "isConnected" is showing as false only.
We can able to connect to the database through persistence provider with the same jDBCConnectionURL, so I think the problem is with the jDBCDriverClass.
we have tried DriverClass as below also:
jDBCDriverClass =  com.microsoft.sqlserver.jdbc.SQLServerDriver
Please let us know if we are missing any thing or using wrong driver class name for mssql.
supandeyAnswer
Oct 30, 2017 10:55 AM UTC
Thanks for clarifying . I could see the same behaviour until i imported the MSSQLConnector_Extension Relation Databases connectors
It appears the JDBC driver already included is not accessible like that, after importing the extension I created a Thing of ThingTemplate MSSqlServer (FYI this added sqljdbc jar in \\webapps\Thingworx\WEB-INF\extensions)
And following configuration :
Hope this'd help.
Oct 27, 2017 8:11 AM UTC
Hi Aahlad, is MS SQL installed as persistence provider or you trying to connect to MS SQL via the RDBMS Extension? It looks like you are mixing two methods. If you are trying to connect via the RDBMS extension you'll need to create Thing of type MSSqlServer ThingTemplate
If you are are attempting to configure it for Persistence Provider it'll need to be done in platform-settings.json file in ThingworxPlatform folder
aallari1-VisitorAuthor
Oct 27, 2017 9:42 AM UTC
Yes we are connecting MS SQL as persistence provider, it is done separately.
But here what we are doing is connecting thing which has "Databse" as base ThingTemplate to MsSQL.
So here all we need is the possible values of DriverClassName for MSSQL.
Please let us know what need to do to achieve this.
supandey5-Regular MemberAnswer
Hope this'd help.
Dec 21, 2017 6:24 AM UTC
Were you able to solve this issue. I'm facing the same
Any information would be helpful
Arvind
Dec 21, 2017 9:19 AM UTC
Hi Arvind, could you please open a new thread, referencing this one and may be also attach the log files or screenshot on your configuration of the JDBC extension?
