Upload excel file and display it in grid
  • June 4, 2018
  • 1985 views
I am working on a project where I need to upload a excel file from my system and display its content in grid. On uploading it should direct to a popup with grid and the contents in excel has to be displayed in grid.
I tried to use file upload but its so confusing and the tutorial too didnt help me understand how to make my scenario possible.
Please provide some help.
V Shalini.
Best answer by mnarang
You can use CSVParser extension from Market place and can read a CSV file in to a grid .There is a service from this extension and that is "ReadCSVFile" .You can take output of this service and map it to grid .But this will only work for CSV file format .
mnarang5-Regular MemberAnswer
Hi, Yeah i have used that service which you mentioned and it is working fine. I have build to three grids. One will fetch data from Windchill. Second grid is attached to the output of ReadCSVFile service & it is working fine. Third grid should display both the output of these grid. I have used the snippet Union to combine both the infotable output. It is working while executing the service but is not working in Navigate mashup.
