11-Garnet
Oct 10, 2025 6:33 PM UTC
Using an LLM with ThingWorx - Latest Version (V2) Update!
🌟New Best Practice: Using LLMs with ThingWorx — Version 2.0 Now Available!
Everyone is talking about Generative AI, and Large Language Models (LLMs) continue to transform how organizations analyze and interact with data. Beyond chatbots and text generation, these models are increasingly being used to make sense of complex industrial data — from factory sensors to production analytics — helping teams make faster, smarter decisions.
ThingWorx, PTC’s Industrial IoT platform, enables secure connectivity to machines, systems, and databases across the enterprise. By linking ThingWorx with an LLM, you can create an AI Assistant for industrial operations that provides insights, answers natural-language questions, and supports data-driven problem solving — all while keeping your operational data secure.
🧩 What’s New in Version 2.0
This new release builds on the original ThingWorx + LLM accelerator and introduces major new capabilities designed to make LLM integrations more powerful, flexible, and enterprise-ready:
  • Integration with ThingWorx Analytics
    The accelerator now connects directly with ThingWorx Analytics Server to interpret results from Signals, Profiles, Datasets, and Predictive Models. You can ask questions like:
    “What factors most influence grinder failures?”
    “How accurate is the predictive model trained on my dataset?”
    The LLM analyzes the context and provides clear, actionable insights in natural language.
  • Router-Based Architecture
    Version 2 introduces a “router” service that allows the LLM to intelligently select which ThingWorx services to execute based on the user’s question. This makes the system more efficient, cost-effective, and scalable — only the necessary data and context are sent to the LLM.
  • Dual-Tab Mashup Design
    The new Insights Mashup includes two tabs:
    • Data Insights (V1) for simple natural-language data queries
    • Analytics Insights (V2) for interpreting ThingWorx Analytics jobs
      The design follows PTC’s corporate template for a modern, consistent experience.
  • Expanded Service Library & Security Enhancements
    The Manager Thing now contains 17 modular services, improving transparency and maintainability.
    This version also incorporates Azure OpenAI best practices for secure key management, data minimization, and compliance.
⚙️ What You Get
The Accelerator includes:
  • A ThingWorx project file (PTCDTS_TWXLLM_V2.xml) that can be imported directly into ThingWorx 9.5 or above
  • An updated Best Practice document (V2) detailing setup, configuration, and validation steps
  • Sample data files (DEMO_BEANPRO_DATA.csv and metadata JSON) used to demonstrate Analytics Insights
Together, these resources show how to connect ThingWorx and an LLM using secure API calls — no external libraries required — and how to extend the architecture to your own factory data and analytics models.
🎥 Watch the New 21-Minute Walkthrough
To accompany this release, we’ve published a 21-minute video overview and live demo that walks through:
  1. How ThingWorx and LLMs communicate
  2. The new router-based architecture in Version 2
  3. How Analytics Insights can interpret predictive model results
  4. A full end-to-end demo showing natural-language queries in both tabs of the accelerator
Whether you’re a developer, system integrator, or operations engineer, this walkthrough shows how easily you can bring Generative AI into your ThingWorx applications.
🚀 Get Started
You can download everything — the Best Practice Document, Accelerator Project, and supporting demo data — from the official GitHub repository:
👉 ThingWorx LLM Accelerator on GitHub
Import it into your ThingWorx environment, enter your Azure OpenAI credentials, and you’ll be up and running in minutes.
By combining ThingWorx’s industrial connectivity with the reasoning and language capabilities of LLMs, this accelerator helps organizations turn raw IoT and analytics data into real, explainable insights — safely, securely, and efficiently.
This video has chapters — open the player menu to jump to any section.
  • 0:00 – Introduction: ThingWorx LLM Accelerator overview (free download on PTC Community & GitHub)
  • 0:50 – Two versions explained: Data Insights (V1) vs Analytics Insights (V2)
  • 1:50 – How Version 1 works: secure LLM queries without sending raw data
  • 3:08 – How Version 2 works: router-based architecture for ThingWorx Analytics
  • 4:19 – Getting started: importing the accelerator project file
  • 5:14 – Uploading the BeanPro dataset and metadata to the file repository
  • 6:39 – Configuring the Manager Thing (GPT Auth, GPT URL, Analytics server name)
  • 9:58 – Exploring backend services (5 services for V1, 17 services for V2)
  • 11:28 – Opening the insights mashup
  • 12:11 – Data Insights demo: asking natural language questions & preparing data
  • 14:55 – Recap: how the LLM produces queries, aggregations, and natural language answers
  • 16:17 – Analytics Insights demo: Prepare Analytics (signals, profiles, predictive models)
  • 17:46 – Analytics Insights demo: asking questions & getting AI-driven answers
  • 20:03 – Conclusion: turning industrial data into actionable insights with Azure OpenAI
Oct 21, 2025 10:00 AM UTC
@d_kessler  - Can you check the content of the V2.0 release in github ? I see only v1 resources.
d_kessler11-GarnetAuthor
11-Garnet
Nov 5, 2025 5:44 PM UTC
Hello - I've updated the structure of the GitHub repository so that now it has the V2.0 files in a new folder "v2.0_current".
Nov 4, 2025 7:41 PM UTC
Is there information on hooking this up to my own data in my TWX environment?
Nov 5, 2025 3:09 PM UTC
I am also having issues with being unable to download the BEANPRO csv and meta data from github. Says something went from when downloading from the given link.
11-Garnet
Nov 5, 2025 6:06 PM UTC
Hi - please try downloading the file using the button highlighted in the attached picture.
Nov 21, 2025 11:53 AM UTC
Related: We created an PoC with MCP for TWX which we can use for a chatbot with TWX data: Blog entry: https://blog.doubleslash.de/en/iot-and-connected-things/llm-based-agent-for-thingworx-architecture-and-implementation-with-mcp/ MCP server is in github if you want to try it yourself!
We really like the idea, which needs some more detailing on how to use it in production. But PoC is really fast - fascinating stuff asking the LLM something and it interacts with ThingWorx (read or write!)
🙂It cannot do data analytics like the approach in the thread - but can be used for gernal information / control. (Or for sure extended with analytic models)
(PTC will release a MCP server themselves in the next months)
