Sep 23, 2019 5:40 AM UTC
convert data into number in datatable
here is my coding which I want to do calculation using datatable data. output should be "NUMBER". but now result is NaN. Could someone help me figure it out?
var query =
"filters": {
"type": "And",
"filters": [
"type": "EQ",
"fieldName": "Department",
"value": "Milk"
"type": "EQ",
"fieldName": "Kategory",
"value": "Production Volume"
var output = Resources["InfoTableFunctions"].RenameField({
t: Resources["InfoTableFunctions"].Aggregate({
t: me.QueryDataTableEntries({ maxItems: undefined,
query: query,
values:undefined,
source: undefined,
tags:undefined
columns: 'value',
aggregates: 'SUM',
groupByColumns: 'value'
to: "value"
var result = parseInt(output/10000);
PaiChungAnswer
22-Sapphire I
Sep 23, 2019 7:46 PM UTC
It looks like you are trying to divide the whole infotable? maybe
var result = parseInt(output.value/10000);
 BTW it seems redundant to rename the field, not sure if you are trying to use the infotable somewhere else as well.
PaiChung22-Sapphire IAnswer
22-Sapphire I
xiaoqw1-VisitorAuthor
Sep 24, 2019 1:26 AM UTC
Thank you for your help. it works!!!
Sep 23, 2019 7:51 PM UTC
Hello Tracy,
Thank you for reaching out on the ThingWorx Developers Community.
I did some quick testing with the code provided and I believe you can achieve the desired results by changing the last line to the following:
When you call for output only the return is an Infotable. If you call for output.value you specifically get the single number from the value field.
Please let me know if this is helpful.
Tyler Misner
ThingWorx Technical Support Engineer
Sep 23, 2019 7:53 PM UTC
Looks like @PaiChung has already replied on this one.
