Jun 29, 2021 5:50 AM UTC
extension
Some extensions are imported in my thingworx composer. Any options available to export those extensions to import it in another server ?
yhanAnswer
Jun 29, 2021 9:31 AM UTC
Please use below attached PDFExtension.zip, it has been imported successfully in my environment. As we talked about previously, the metadata.xml should be at the root folder of the zip file.
Jun 29, 2021 6:06 AM UTC
No need to export, you can get all extensions from this path: \ThingworxStorage\extensions. Remove the .chk file first – then zip the remaining files and import that to a new instance (CS321263)
Jun 29, 2021 6:43 AM UTC
While importing Extension it showing error >> Error [authenticating connection], Server websocket will be closed. cause: Missing application key!
But the applicationkey is present
Jun 29, 2021 6:55 AM UTC
Could you tell me the steps for how you import the extension, like below?
1. zip the extension folder
2. Visit the thingworx home page > import > import extension
3. It said import failed
4. Visit monitoring > application log > check the error
Am I right? If so, I'm afraid its not the exact error message about import failure.
