Best answer by emscur
Hello @RM12,
I provided solution to this in another thread here.
Emmanuel
Rocket_Max
Hello @RM12
These techniques are described in the following ThingWorx community posts
BR,
Max
one of the solution can be your source datashape hold a filed of type hyperlink and you can add your desired links to the infotable columms using this DS. Map this infotable to the advance grid and it will bring up the column containing link to your web links.
RM1214-AlexandriteAuthor
 Thanks for your reply .I followed your steps for link  I have taken a hyperlink link field in the data shape  and give link,  but it is not showing on the advance grid .
Please refer the below attachment
I am not sure what's wrong in your case, but I had a small sample in my composer. I am attaching the entities if you can import and check this. Let me know if still it does not work.
