Thingworx Navigate and Flex PLM Integrattion
  • February 11, 2020
  • 2074 views
Is thingworx navigate integration with Flex PLM possible?
If yes, which are the connectors or utilities to be used for integrating?
Thanks in advance.
Kiran Gurav
Best answer by Arshad
Hi Kiran,
Currently, there are no app in Thingworx Navigate to view Flex objects.
However, there's Thingworx - Tech Pack Connect App which provides the ability to access specification artifacts from PTC Windchill FlexPLM.
More information available at Tech Pack Help Center
You can also build Dashboard Definition using Thingworx mashup, refer Creating Dashboard Definition
Arshad
Arshad17-PeridotAnswer
Hi Kiran,
Arshad
Support
February 21, 2020
Hi @Kiran1.
If the response provided by @Arshad answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
