Apr 26, 2017 2:17 PM UTC
3D Widgets showing no data from TWX
Hey all,
I have rebuild the Blue Pump Demo for the Hololens and with gestures and voice commands.
Everythings is working fine instead of the "live" data coming from ThingWorx.
I am using a Thing that is generating random data on his properties. I use the external data panel in Studio to bind the properties to 3D gauges and 3D Labels in the Hololens experience. In the Composer and in the experience preview i see that data is changing but on the Hololens I see no data.
Has anybody the same issue?
Seb
mthakkerAnswer
Apr 27, 2017 1:35 PM UTC
Did you allow anonymous activity on the "Thing" for "Property Read," "Service Execute," and "Event Subscribe"?  If you created a new Thing, these permissions need to be enabled for that Thing.
mthakker5-Regular MemberAnswer
SebB13-AquamarineAuthor
Apr 28, 2017 11:58 AM UTC
Thanks Milan, that was the case. I missed that the hololens experiences are always public.
May 5, 2017 5:45 AM UTC
Sebastian would you share that thingmark? :-))
May 5, 2017 6:50 AM UTC
Hey Martin,
sure here is the ThingMark (530:99), but I am still working on the experience to bring in more features.
I have implemented one gestures and three voice commands so far:
  • "Play Sequence" / doubletap - starts disassembly sequence
  • "Show Data" - shows simulated sensor data
  • "Remove Data" - hides sensor data
Sep 6, 2017 7:14 AM UTC
Hello Sebastian
would you be kind to share step by step creating voice commands for hololens?
Kind regards
Daniel
