loyangAnswer
Oct 25, 2021 12:43 AM UTC
The cause of the problem has been found. It is related to the loaded user extension widgets (Studio 3d chart widgets  https://github.com/ptc-iot-sharing/3DChartWidgetStudio ). After deleting the extended widgets , the problem is solved.
Oct 24, 2021 3:33 PM UTC
Here is a solution from another thread: "Could try removing the node_modules symlink under Documents\VuforiaStudio\Projects. That link will get re-created the next time you open Studio".
Link: https://community.ptc.com/t5/Vuforia-Studio/What-s-New-in-Vuforia-Studio-8-3-1/m-p/558901#M3592
loyang10-MarbleAuthor
Oct 24, 2021 3:48 PM UTC
I have tried the method of removing the node_modules symlink under Documents\VuforiaStudio\Projects, and it can't solve this problem.
 it maybe related to the modules being moved to the @unknown directory.
loyang10-MarbleAuthorAnswer
