May 12, 2020 12:13 PM UTC
An error shows up when publishing a project
Hi there!
I'm facing an error when trying to publish a sample project.
I've successfully downloaded and installed the Vuforia Studio software, logged into my account(Username: hayk.nazaryan@ni.com) and created a sample project. I configured the Default Experience Service URL and have admin privileges, but when I hit Publish, after preparing and uploading the content, publishing fails with an error message "Permission denied uploading". When I check the logs, there is a message "Insufficient permissions to access resource","errorCode":403,"error".
I reinstalled the software several times, deleted the "builder-settings" file at C:\Users\Documents\VuforiaStudio and the issue still remains. Also what I've noticed in this file is "https://16e3e79bf17b30d7.studio-trial.vuforia.io" changed to "https://ni-dev.es.thingworx.com" with a true flag for "acceptedLicense".
Please provide some guidance to resolve the problem.
Thank you,
Hayk
sdidierAnswer
May 13, 2020 8:50 AM UTC
Hello Nazaryan,
I have alook to this article :
https://www.ptc.com/en/support/article/CS268110
  • Does the user has have the tag PTC.Authentication:PTCAccount in ThingWorx ?
  • Does the Developers group have Read Permissions for Resources Collection in Design Time ?
Best regards,
Samuel
May 12, 2020 2:16 PM UTC
I have some questions :
  • Did you add your user into the Developers group in ThngWorx ?
  • Do you have the same issue when using another Administrator user ?
Best regards,
Samuel
May 13, 2020 7:49 AM UTC
Hi Samuel,
Thanks for your prompt reply!
  • yes, my user has been added to the Developers group in ThngWorx
  • no issues found when using another Administrator account
Let me know in case any additional information is needed.
Hayk
sdidier17-PeridotAnswer
Hello Nazaryan,
Best regards,
Samuel
