Jun 11, 2019 12:52 PM UTC
Can't hide components in Vuforia Studio
Hi.
I'm trying to hide some 3D-Labels and 3D-Images in the Canvas to have a better overview while developing my experience, but it does not work. If I select the widget and click the "Hide Components"-Button nothing happens. Do I miss something?
Is I click on the widget the Button is active but the widget still vissible??? (see attached screeshot)
ytellaAnswer
Jun 17, 2019 6:56 PM UTC
Hi @feil,
Sorry, I misunderstood your question. Have you tried the opacity property of the 3D widget? For example, Select a 3D-Image and then make the value of the opacity property to 0 as shown below:Screenshot_21.png
Jun 11, 2019 4:21 PM UTC
Hi @feil ,
One of the ways to hide components from canvas is as follows:
  • Uncheck the visible property of 3D-Image/3D-Label
  • Create an application parameter by clicking +sign next to Application Parameters -> Type your desired name in the name field and set it's value to true as shown below:Screenshot_19.png
  • Drag and drop the bind icon of application parameter on to the visible property of 3d-Image/3DLabel as shown below:Screenshot_16.png
  • Click Home.js and write the below function:
    • $scope.visibleImage = function() {
                  $scope.app.params.visibleparameter = false;
  • Drag and drop a button widget on to the 2D canvas and call the above js function in it's click event as shown below:Screenshot_17.png
  • Save and test the experience
Hope this helps!
feil1-VisitorAuthor
Jun 12, 2019 6:16 AM UTC
Hi.
I think I was missunderstood.
Hiding thinks in an experience is no problem.
I wanted to hide elements while im developing the experience. At the moment I have so much components on the screen on I can't see some thinks anymore If I drop new thinks on the canvas.
Just want to hide som components while im working on the experience, not within the experience.
ytella17-PeridotAnswer
Hi @feil,
