Display the next step name from Creo Illustrate
Need advise for my problem regarding my concern on displaying the next step instruction from Creo Illustrate. I need Vuforia to display the current instruction and the next instruction when user click on button. For now, the current step instruction are being displayed, but now I have to display also the next instruction.
Hope anyone can advise me on this matter. Really appreciate it!
sebbenAnswer
 you can use the following JS:
var instruction = '';
$scope.$on('newStep', function(evt, arg) {
 instruction = arg
$scope.UpdateInstructions = function()
 $scope.app.params.StepText = instruction;
  1. Call  ‘UpdateInstructions’ from the ‘Play Started’ event of the model
  2.  You must have ‘StepText’ application parameter
  3. Bind ‘StepText’ to a label showing instructions on the UI
I hope that helps.
sebben14-AlexandriteAnswer
 instruction = arg
I hope that helps.
That is a very helpful solution. But it only provide the step name and (current step / total steps)
Is there a way to read the value of the 'step_description' parameter from the .pvi file?
Thanks in advance!
Cheers
Marco
I guess it not feasible right now hence the .pvi is embedded in the PVZ file.
Easy way to accomplish this by far would be copy those description to an object/json outside of the PVZ for further usage.
Really looking forward that Vuforia Studio would have this capability someday, along with Annotations.
regards,
ClarK
