8-Gravel
October 22, 2020
Failed to publish experience
  • October 22, 2020
  • 2956 views
Not able to publish experiences:
[2020-10-22T13:55:51.604Z] error: [twx-studio:tgt-gen.img] Response code 403
[2020-10-22T13:55:51.604Z] error: [twx-studio:tgt-gen.img] Could not retrieve signature,  {"message":"Insufficient permissions to access resource","errorCode":403,"error":{}}
[2020-10-22T13:55:51.604Z] error: [twx-studio:tgt-gen.img] Failed to generate the data set for model E:\Projekte\Vuforia_Studio_Data\Documents\VuforiaStudio\Projects\KTM_Bike\dist\app\resources\Uploaded\IllustrationKTM.pvz undefined
[2020-10-22T13:55:51.604Z] error: [twx-studio:projectHelper] publishTask error for project KTM_Bike Error: Publish failed, issue generating model target information
    at _Error (C:\Users\dkirazli\AppData\Roaming\VuforiaStudio\studio-download.vuforia.io\node_modules\target-generator\lib\modelTargets.js:23:17)
    at ModelTargetGenerator.generateDataSet (C:\Users\dkirazli\AppData\Roaming\VuforiaStudio\studio-download.vuforia.io\node_modules\target-generator\lib\modelTargets.js:206:13)
    at runMicrotasks (<anonymous>)
    at processTicksAndRejections (internal/process/task_queues.js:97:5) {
  i18n: true
[2020-10-22T13:55:51.605Z] error: [twx-studio:api] Error occured while publishing project KTM_Bike Error: Publish failed, issue generating model target information
  i18n: true
Hello Dkirazli,
It seems this Vuforia Experience Service doesn't have Model Target enabled.
I would recommand at first to check this article :
https://www.ptc.com/en/support/article/CS279248
Best regards,
Samuel
dkirazli8-GravelAuthor
8-Gravel
October 23, 2020
Hi Samuel,
Thanks for your reply.
What is really strange that it was working 1 or 2 months ago.
And as it is running on the cloud, I have no access to the local files to make changes and restart it.
Br,
Deniz
Hello Deniz,
It is needed to open a case to PTC Cloud.
They will check config file and if they don't find the right setup, they will contact Technical Suppport internaly directly.
Like that, we will be able to investigate directly on the instance.
I am a Technical Support Engineer at PTC but I don't have the access to any instance of customers hosted at PTC.
This is the process to have a right security about environments.
Best regards,
Samuel
