Integration Windchill and Vuforia Studio
Hello all,
Is there any possible way to integrate Windchill and Vuforia studio. My use case here is, I need to list out all the available 3D model available in Windchill into Vuforia Studio screen, based on user selection I need to show 3D model in 3D Model widget.
VR
Today, it is not possible.
But I have heard that R&D is working on SSO in Vuforia Experience Service.
So, it means, it will be possible to connect Vuforia Experience Service to ThingWorx embedded in PTC Navigate.
PTC Navigate is connected to Windchill with the same logon.
A behavior is also developing to be able in a such environment to have data from Windchill exposed in PTC Navigate.
At the end, it will be possible to see some data from Windchill in an Experience.
Both behavior SSO and have access data from Windchill are depending each other but I am not sure if they will be released at the same time.
Best regards,
Samuel
Velkumar19-TanzaniteAuthor
Hi @sdidier
Thanks for your reply. Then is there a way to load 3D model from Thingworx repository to Experience dynamically ?
/VR
@Velkumar I am looking for the solution of your query you put few years ago. I also would like to get the 3D model dynamically in vuforia studio. Would you like to please write about your approach here. It would be really helpful for me because i want this exact same thing.
Hi @MA8731174
You can dynamically download PVZ file from Windchill using WRS
Article - CS350641 - How to get the Representation ID of an Assembly in Windchill Rest Services? (ptc.com)
Unfortunately, I don't have test Windchill environment to provide full solution.
/VR
