Dec 18, 2023 9:58 AM UTC
PDF Viewer Extension not working
Dear community
I've noticed that the PDF Viewer Extension does not work any more.
Attached is the extension file that I am using.
Thanks for your help!
Best wishes
Alex
Dec 27, 2023 11:04 AM UTC
Hi @AlexK ,
I will check this. So, far this should be an issue for mobile, right? because for eyewear device- is supported via the 3D document /according to the Vuforis Studio help
So far I know there are 2 different versions of this extension to downlaod
Download 1.) PDF extension 0.3 version  (Tested on Vuforia 8.5.x and 9.0.0) or the newer one 2.) PDF extension 0.5.1 version  (the old PDF 0.3 version does not work since 9.0.x.a the new 0.5.1 version works on later versions according to a statement of TS team and I  just received a feedback  which confirmed  that it worked on  9.16 on iOS -  with simple test proejct)
What version did you use and what of mobile platfrom? Thanks
Hi @AlexK ,
AlexK15-MoonstoneAuthor
Jan 9, 2024 10:48 AM UTC
Hi Roland,
Thanks, it works with 0.5.1!
Best wishes
Alex
