Aug 16, 2019 9:36 AM UTC
Play sequence by buttons
Hi there,
I am working on a demonstration and there is a 3D model containing 2 - 3 sequences.
I knew that I can use the select widget to choose the target sequence, but I would prefer play different sequence by clicking buttons for a better trial experience.
For example, if I click button A, the first sequence is played. Likewise, if I click button B, another sequence will be played.
Is there any way to perform such function in Vuforia Studio? Or can I do that through writing a script?
InfinityXAnswer
Aug 19, 2019 6:36 AM UTC
yes it is possible
u might have .pvz model with you . so do one thing save that file as .zip by renaming. and extract the file, you will get a lot files including .obj and .pvi
so in that .pvi files are nothing sequence file to run , suppose you have 4 sequences then you will find 4 .pvi files
now with the help of these files You can run 4 sequences with 4 different buttons
you need to provide 4 button in 2D canvas and bind all those button with model first and in home.js view you need to write javascript code for that given below:
$scope.r1= function()
$scope.view.wdg['model-1']['sequence'] = 'app/resources/Uploaded/l-Creo 3D - RED.pvi';
now this is javascript to run only 1 sequence , so if u have 4 sequence then you need to write above lines 4 times by making some changes in that
now in above javascript
"r1" is assinged to respective button binding
"l-Creo 3D - RED.pvi" is respective sequence file which we get from extract of zip file
suppose to bind A button to model to run sequence then u need to right below code in click area of A button
r1();
means if u click on A button respective Sequence file will run
similarly u need to perform same procedure to other button by changing the red part in javascript
Aug 19, 2019 4:57 AM UTC
Yes, you'd just need to write some JS functions to set the sequence for the model widget and then kick off the playing of the sequence.
There's plenty of examples of setting the sequence via JS here in the forums, but here's and example of what you would do:
$scope.animation1 = function () {
  $scope.view.wdg['model-1']['sequence'] = "app/resources/Uploaded/l-Creo 3D - Figure 1.pvi";
   angular.element(document.getElementById('model-1')).scope().play();
Hope this helps.
Aug 26, 2019 4:09 AM UTC
Thanks for the help and sorry for the late reply.
Is this line: angular.element(document.getElementById('model-1')).scope().play();,
is the javascript for playing next step of the sequence?
So, if I want to rewind and play my sequence by clicking a button, can I write something like this?
angular.element(document.getElementById('model-1')).scope().rewind();
Aug 26, 2019 6:29 AM UTC
yes it is possible i guess
just you need to use 2 button instead of 1
like for button 1 you need to apply  javascript:
for button 2 you need to apply javascript:
InfinityX1-VisitorAnswer
yes it is possible
r1();
