Re: Model pvz sequence binding at runtime
  • May 3, 2018
  • 3 replies
  • 6634 views
I created mulitple sequences in a model. Now i have binded it with application parameter . i want to know how can i provide values to that parameter at runtime in Home.js or elsewhere.
basically i want to change the sequence by calling different functions.
    Best answer by A_Macierzynski
    You need to go to the widget property through the $scope. You can find that your model widget has something called sequence property.
    Sequences created in Creo software are saved in PVI format and it is a part of the PVZ model file. You can try to open PVZ file as an archive to see that it contains your sequences in separated PVI files.
    So now you can try with two things:
    1. Assign the sequence name directly to the property like this: $scope.view.wdg['model-1'].sequence = "mySecondSequence";
    2. Try to assign it by path like it is shown above. (it can be painful to figure out correct path).
    I didn't test it yet, so you can give me a feedback if it is working as you want.
    Adam
    Vivek Jain​: Yes, you can initialize and assign values to variables in Home.js and can also write JS functions which you would like to be called in case of some event or activity.
    -Durgesh
    August 31, 2017
    I am aware of initializing the variables in Home.js.
    I want to know in particular about the sequence property of model and how to set it for multiple sequences.?
    Adam
    Also, can check and try
    $scope.view.wdg['model-1']['sequence'] = seqname;
    Hello
    I've tried to use .pvi file in hololens according to proposed solution above and are getting following error.
    Uncaught TypeError: Cannot read property 'stepVec' of undefined
        at vuforia-angular.js:1568
    And in debug mode I'm getting error on bold marked line:
    function loadSequence(url, speed, callback) {
            // ignore speed, native sequencer doesn't have such concept
            var pviParams = {
                modelID: MODEL_ID,
                url: url
            renderer.loadPVI(pviParams, function (sequenceData) {
                // load completed callback
               STEPS = sequenceData.stepVec;
                TOTALSTEPS = STEPS.length;
                FIRST_STEP = 0;
                // if step 0 has acknowledgment, start on step 0, otherwise start on step 1
                if ((TOTALSTEPS > 0) && (STEPS[0].acknowledge === false) ) {
                    FIRST_STEP = 1;
                // ThingView might still be on step 0, but the next step to be played is CURRENT_STEP
                CURRENT_STEP = FIRST_STEP;
                if ( callback !== undefined ) {
                    callback(undefined, undefined);
            }, function () {
                // load failed callback
                console.log(MODEL_ID + " failed to load pvi " + url);
    same issue here, any solutions?!
