Oct 8, 2021 2:27 PM UTC
ThingMark scan logs
We are sharing our ThingMarks with our customers and we would like to see how often a ThingMark is scanned. Each marker is for a predefined customer only. What I am looking for is a log that contains the lifetime history of the usage of a specific ThingMark in the terms of the number of scans and the datetime of each scan. Is it possible to change this command:
<es-protocol>://<es-host>:<es-port>/ExperienceService/
compliance/views?startDate=<start-date>&endDate=<enddate>
 in such a way that I can find the same information but for a specified ThingMark?
Example call:
compliance/views?key=urn:vuforia:vumark:1234:1&startDate=<start-date>&endDate=<enddate>
(I tested this setup and it only results in the overall views and billables).
Example result:
 "views-marker" = 235,
 "billables-marker" = 156,
 "views" = 470,
 "billables" = 327
I thought it would be nice to see the marker values and the overall values for comparison in this example, but is not required.
Many thanks in advance.
With kind regards,
Martini3119
Oct 11, 2021 9:42 AM UTC
Hi @Martini3119 ,
so far I know, one possible option is that we can receive the rawData (requires a admin account for the experience service)
Specific time frame:
GET <ES-protocol>://<ES-host>:<ES-port>/ExperienceService/compliance/views?startDate=<start-date>&endDate=<end-date>
For the detailed client information (such as IP/useragent information), below REST API can be used:
GET <ES-protocol>://<ES-host>:<ES-port>/ExperienceService/compliance/views?startDate=<start-date>&endDate=<end-date>&rawData
JSON object with views and billables will be returned
views = gross number of public views by non-registered users
billables = net number of public views by non-registered users
example of such call (call all views after.01.2019 -> to the current time) in chrome browser:
https://xxxxxxxx.studio-trial.thingworx.io/ExperienceService/compliance/views?startDate=2019-01-01T00%3A00%3A00.000%2B05%3A30&endDate=1000000000000000&rawData
and sample results below : ( the last few lines):
,{"id":161,"ip":"xx.xxxx.xxxx.184","useragent":"VuforiaView/9.2.1 (iPad7,5; iOS14.6)","namespaceid":".","store":"projects","path":"/test-picker-shader/index.html","contentname":"test-picker-shader","billable":0,"createdon":"1633943984247"}]}
So that we can find here in the rawData the project name and the ip where it was called but also the client info. you can check the rawData for called projects - because there e is thingmark - project name relation
Hi @Martini3119 ,
Oct 11, 2021 3:10 PM UTC
Hi @RolandRaytchev ,
Cool! Works like a charm:
 "id": 498,
 "ip": "xxxx",
 "useragent": "Dalvik/2.1.0 (Linux; U; Android 11; AC2003 Build/RP1A.201005.001) VuforiaView/9.2.3.2680 (AC2003; 11)",
 "namespaceid": ".",
 "store": "projects",
 "path": "/xxxx/index.html",
 "contentname": "xxxx",
 "billable": 1,
 "createdon": "1633963917395"
 "id": 499,
 "ip": "xxxx",
 "useragent": "Mozilla/5.0 (Linux; Android 11; AC2003 Build/RP1A.201005.001; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/94.0.4606.71 Mobile Safari/537.36 VuforiaView/9.2.3.2680 (AC2003; 11)",
 "namespaceid": ".",
 "billable": 1,
 "createdon": "1633963917793"
I have a few follow-up questions, if you have the time:
  1. What is the meaning of the "createdon" value? The first ten are the datetime timestamp. As seen in my example, it says 1633963917 (10/11/2021, 4:51:57 PM), but what are the last three numbers for?
  2. Why is the call logged twice, despite being logged in a slightly different manner? Next to the difference in the user agent, there does not seem to be any valuable information present.
  3. It seems I cannot see this data from experiences that require authentication. Could you confirm this, please?
Many thanks in advance!
With kind regards,
Martini3119
Oct 13, 2021 1:01 PM UTC
Hi @Martini3119 ,
because I found this info after some internal database search - so far I will answer your question so far I know:
-1.) the last 3 number are possibly the value of the milliseconds - because time value is based . so far I know on milliseconds
2.)I believe this question is related to the example call in last post which is encoded:
So when we decode it then it will look like (see also https://www.url-encode-decode.com/ )
https://xxxxxxxx.studio-trial.thingworx.io/ExperienceService/compliance/views?startDate=2019-01-01T00:00:00.000+05:30&endDate=1000000000000000&rawData
So we have the date&time full format + time zone and the second parameter  is some large value which is remote future.
3.) definitely you need to be an user with  admin permission - means  you need to use credential or app key. That means that on browser you need to authenticate but when you use something like node.js or javascript you can do this by some parameters (using fiddler you can record you call from browser to experience service and check shat of parameter are used. Then you can try this in POSTMAN (google app) and when this work then translate the call to the desired language -node.js, javascript etc. So far I think you can also check the request in the google browser Shift-String-I  then performs the request and check the Header for the Network section – especially  the Authorization parameter (app key format string) :
Accept-Language: en-US,en;q=0.9
Authorization: Basic cnJheXxxxxxxxxxxxxxxxxxx0A=
