Mar 13, 2018 3:24 PM UTC
Unable to Publish any Project
I am currently unable to publish any project from Thingworx studio.
When I try to publish I get the following error message.
[03/13/2018 14:00:15] info: [twx-studio:projectHelper] buildApp Sandvik_1520936936527already in progress. Trigger build after it completes.
[03/13/2018 14:00:16] info: [twx-studio:projectHelper] buildApp Sandvik_1520936936527already in progress. Trigger build after it completes.
[03/13/2018 14:00:26] Studio Version 8.2.0 (8.2.0.2742)
[03/13/2018 14:00:26] Status Message: Version 8.2.0 (8.2.0.2742)
[03/13/2018 14:00:26] Checking for updates from https://studio-download.vuforia.io/downloads/ThingworxMobileBuilderApp.application
[03/13/2018 14:00:27] Starting node.exe
[03/13/2018 14:00:28] info: [twx-studio:initializer] Node version: 8.9.3
[03/13/2018 14:00:28] info: [twx-studio:initializer] ThingWorxStudio launched with the following arguments: _=[C:\Users\rirelandbowcott\Documents], help=false, version=false, $0=..\..\..\..\..\..\Roaming\ThingworxStudio\studio-download.vuforia.io\dist\server\index.js
[03/13/2018 14:00:28] info: [twx-studio:initializer] ThingWorxStudio dir: C:\Users\rirelandbowcott\Documents\ThingWorxStudio , home dir: C:\Users\rirelandbowcott\Documents
[03/13/2018 14:00:28] ar-extension version 8.2.0 (1.22.941)
[03/13/2018 14:00:30] info: [twx-studio:index] Studio Ready: listening on 127.0.0.1:3000
[03/13/2018 14:00:33] GET /%7B%7B::projectType.imgPath%7D%7D 200 3.943 ms - 2747
[03/13/2018 14:00:33] GET /%7B%7B::view.imgPath%7D%7D 200 3.506 ms - 2747
[03/13/2018 14:00:33] GET /%7B%7B$root.currentProject.thingServerQRCode%7D%7D 200 3.939 ms - 2747
[03/13/2018 14:00:33] GET /%7B%7BviewType.imgPath%7D%7D 200 1.022 ms - 2747
[03/13/2018 14:01:19] GET /%7B%7B::projectType.imgPath%7D%7D 304 3.030 ms - -
[03/13/2018 14:01:19] GET /%7B%7B::view.imgPath%7D%7D 304 4.003 ms - -
[03/13/2018 14:01:19] GET /%7B%7B$root.currentProject.thingServerQRCode%7D%7D 304 4.125 ms - -
[03/13/2018 14:01:19] GET /%7B%7BviewType.imgPath%7D%7D 304 4.812 ms - -
[03/13/2018 14:01:23] GET /api/switch 401 2.967 ms - -
[03/13/2018 14:01:23] GET /api/switch 200 0.179 ms - -
[03/13/2018 14:01:23] POST /api/unpublish/ 500 31.696 ms - 42
[03/13/2018 14:01:25] GET /api/switch 200 0.109 ms - -
[03/13/2018 14:01:53] GET /api/switch 200 0.212 ms - -
[03/13/2018 14:01:53] POST /api/unpublish/ 500 4.264 ms - 42
[03/13/2018 14:01:55] GET /api/switch 200 0.208 ms - -
[03/13/2018 14:01:55] POST /api/unpublish/ 500 1.737 ms - 42
[03/13/2018 14:01:56] GET /api/switch 200 0.097 ms - -
[03/13/2018 14:01:56] POST /api/unpublish/ 500 1.826 ms - 42
[03/13/2018 14:02:00] GET /api/project/Sandvik/zip/ 200 499.721 ms - 38114368
[03/13/2018 14:02:11] GET /api/switch 200 0.217 ms - -
[03/13/2018 14:02:11] POST /api/unpublish/ 500 4.889 ms - 42
[03/13/2018 14:02:58] GET /api/switch 200 0.274 ms - -
[03/13/2018 14:02:58] POST /api/unpublish/ 500 2.775 ms - 42
[03/13/2018 14:03:19] GET /home 200 0.957 ms - 2747
[03/13/2018 14:03:20] GET /%7B%7B::projectType.imgPath%7D%7D 304 0.813 ms - -
[03/13/2018 14:03:20] GET /%7B%7B::view.imgPath%7D%7D 304 1.668 ms - -
[03/13/2018 14:03:20] GET /%7B%7B$root.currentProject.thingServerQRCode%7D%7D 304 0.346 ms - -
[03/13/2018 14:03:20] GET /%7B%7BviewType.imgPath%7D%7D 304 0.362 ms - -
[03/13/2018 14:20:31] GET /api/switch 200 0.201 ms - -
[03/13/2018 14:20:41] GET /api/switch 200 0.289 ms - -
[03/13/2018 14:20:58] info: [twx-studio:projectHelper] Building ves-ar-extension app: Sandvik
[03/13/2018 14:21:00] info: [twx-studio:projectSettings] Notify preview windows: private-room-Sandvik
[03/13/2018 14:21:23] info: [twx-studio:projectHelper] Building ves-ar-extension app: Sandvik
[03/13/2018 14:21:24] info: [twx-studio:projectSettings] Notify preview windows: private-room-Sandvik
[03/13/2018 14:21:24] GET /api/switch 200 0.187 ms - -
[03/13/2018 14:21:24] POST /api/publish/ 500 25.276 ms - 42
[03/13/2018 14:21:33] info: [twx-studio:projectHelper] Building ves-ar-extension app: Sandvik
[03/13/2018 14:21:34] info: [twx-studio:projectSettings] Notify preview windows: private-room-Sandvik
[03/13/2018 14:21:55] info: [twx-studio:projectHelper] Building ves-ar-extension app: Sandvik
[03/13/2018 14:21:56] info: [twx-studio:projectSettings] Notify preview windows: private-room-Sandvik
[03/13/2018 14:21:56] GET /api/switch 200 0.195 ms - -
[03/13/2018 14:21:56] POST /api/publish/ 500 4.887 ms - 42
[03/13/2018 14:36:31] info: [twx-studio:projectHelper] Building ves-ar-extension app: Sandvik
[03/13/2018 14:36:33] info: [twx-studio:projectSettings] Notify preview windows: private-room-Sandvik
[03/13/2018 14:36:38] GET /design/Sandvik 200 1.164 ms - 2747
[03/13/2018 14:36:40] GET /%7B%7B::projectType.imgPath%7D%7D 304 0.777 ms - -
[03/13/2018 14:36:40] GET /%7B%7B$root.currentProject.thingServerQRCode%7D%7D 304 0.842 ms - -
[03/13/2018 14:36:40] GET /%7B%7BviewType.imgPath%7D%7D 304 0.982 ms - -
[03/13/2018 14:36:40] GET /%7B%7B::view.imgPath%7D%7D 304 2.031 ms - -
[03/13/2018 14:36:40] GET /api/switch 200 0.141 ms - -
[03/13/2018 14:36:54] info: [twx-studio:projectHelper] Building ves-ar-extension app: Sandvik
[03/13/2018 14:36:55] info: [twx-studio:projectSettings] Notify preview windows: private-room-Sandvik
[03/13/2018 14:37:27] info: [twx-studio:projectHelper] Building ves-ar-extension app: Sandvik
[03/13/2018 14:37:28] info: [twx-studio:projectSettings] Notify preview windows: private-room-Sandvik
[03/13/2018 14:37:28] GET /api/switch 200 0.164 ms - -
[03/13/2018 14:37:28] POST /api/publish/ 500 15.745 ms - 42
Mar 13, 2018 6:51 PM UTC
Is this a trial instance? If so, what is the ES URL you are attempting to publish to? Can you share a screenshot of the info tab of the experience? Have you ever been able to publish experiences?
Mar 14, 2018 9:19 AM UTC
Yes, this is currently a trial version although hopefully not for long and yes, I have been able to publish in the past so i'm not sure what has changed.
Please see the screen grabs below. Hopefully they contain the information you wanted.
