Apr 13, 2017 11:10 AM UTC
change the style of widget dynamically
Hi ,
     I want to change the style of the widget dynamically, for ex. i have to change the color of label on button click or any other event of any widget.How can i do that?
Quadir
Apr 14, 2017 4:46 PM UTC
Hi Qadir,
You can change the color both statically and dynamically in ThingWorx Studio. For static (i.e., stable throughout the experience), you can either write a custom css (under Styles-> Application) or you can use ionic framework classes to auto-define styles, please follow the ionic framework reference doc.​ As shown below, I was using button class 'button-balanced' to change the background as green.
Here, I'm using 'energized' class on a label to change the color of text.
For dynamic styles, i.e., change on button click, you can write a custom JS code to toggle css class or execute a JS function to change the styles of a widget class. FYI, right next to click event you can click on the 'JS' button, here whichever code we write will be executed on click event. Wrt js code, I'll leave it to your usecase specific requirement and consensus.
Giri
Apr 16, 2017 11:24 PM UTC
If you want to remove a css class and add a new one to a button dynamically, here is a code sample:
if (angular.element(document.querySelector('[widget-id="button-1"] button')).hasClass("OldButton")) {
angular.element(document.querySelector('[widget-id="button-1"] button')).removeClass("OldButton");
angular.element(document.querySelector('[widget-id="button-1"] button')).addClass("NewButton");
Jun 29, 2018 10:12 PM UTC
Hi rabernathy,
Thank you for your reply. This works great with a button!
thank you so much!
Oct 19, 2017 7:22 AM UTC
Hi Neetu,
I think you are asking for ThingWorx Composer Mashups not ThingWorx Studio, and Giri it's answering for ThingWorx Studio.
On the case of ThingWorx Composer Mashups, you should look at ValueDisplay widget, you can have Conditional Styling using "ValueFormat" property.
Best Regards,
Carles
Oct 19, 2017 1:11 PM UTC
Hi Carles,
Thanks for your response.
What I understood from ValueDisplay widget is to mainly display the data.
What I want to do is to apply css styles to existing widgets. How would I achieve this in Thingworx Composer  Mashup ?
Neetu
Oct 20, 2017 11:59 AM UTC
You can customize the styles using Style properties, before you asked for Dynamic Styling not static. But anyway, yes it kind of limited, but depending on what you need to get you can do it, this is for Industrial IoT not mass wide user interface.
Anyway, always you can chose the UI framework that you want and use ThingWorx REST API.
Best Regards,
Carles.
