Apr 2, 2025 1:44 PM UTC
Fetch BOM Data from WRS
I am using Windchill PDMLink Release 12.1 and Datecode with CPS 12.1.1.0
Trying to fetch BOM data with ID e.g.OR:wt.part.WTPart:455420, in the WRS Domain under Product Management Domain under POST GetBOM i enter Parameters and CSRF TOKEN from /servlet/odata/PTC/GetCSRFToken()
the Parameters
Name Description
$select
string
(query)
$select
$expand
string
(query)
Components($expand=Part($select=Name,Number),PartUse,Occurrences;$levels=max)
CSRF_NONCE *
string
(header)
wq4/k91jTdavRJ8Olv9d34oJDJLcCNM5s4FQ37gbFbObF/hh+pgU+ocrf73iE647gcNW1vIIfeuVdag68ZsHq+1Te+6ZcKVD9MgO9q8Nda/VEKp9p5xwyqlUKJnnfMVHl95c9u87err1D9NMgMplqqsAcA==
PartId *
string
(path)
body *
object
(body)
Edit Value
Model
"navigationCriteriaId": ""
and click execute
Here are the errors that I faced
when i paste the link in the POSTMAN I am getting error
"error": {
"code": null,
"message": "The syntax of the JSON document is not valid."
    Apr 3, 2025 10:02 PM UTC
    I will share the steps for postman:
    1, Get latest CSRF NONCE
    URL: http://<server>:80/Windchill/servlet/odata/PTC/GetCSRFToken()
    Request Type: GET
    Only Authorization tab needed to be filled in Postman
    Copy the Nonce Vale
    2. Get the OID for Part
    URL: http://<server>:80/Windchill/servlet/odata/ProdMgmt/Parts?ptc.search.latestversion=true&$filter=View eq 'Design' and Number eq 'DQ001'
    Request Type: GET
    Copy the part ID
    3. Exceute the Get BOM
    URL: http://<server>:80/Windchill/servlet/odata/v4/ProdMgmt/Parts('OR:wt.part.WTPart:2230714')/PTC.ProdMgmt.GetBOM?$expand=Part,PartUse,Occurrences
    Request Type: POST
    Replace the Part ID in step 3 url as fecthed in step 2
    Also, add a parameter as CSRF_NONCE with value as fetched in step 1 in the headers tab in Postman as shown below
    Give the body as {} in the Body tab in Postman as shown below
    Then execute the request to get the result.
    Fadel
    23-Emerald II
    Apr 2, 2025 6:06 PM UTC
    I guess you need a nab critera (Filter) , take a look at https://www.ptc.com/en/support/article/CS299749
    Buiꓘa
    Apr 3, 2025 8:20 AM UTC
    Is the Navigation Criteria even neccassary?
    Request Type: GET
    Copy the Nonce Vale
    Request Type: GET
    Copy the part ID
    Request Type: POST
