How to listen to event while moving object from one container to another using move action?
  • May 23, 2023
  • 2 replies
  • 1791 views
Best answer by BjoernRueegg
I'm not sure but I would guess:
wt.inf.container.WTContainerMoveEvent
with  PRE_MOVE and POST_MOVE
Hi @KS_9713081 ,
Update the following properties in wt.properties file to generate events log/information when move action is performed.
wt.services.verbose=true
wt.services.verboseEvents=true
Hi....Thank you ..It works for me
I also need to configure WTContainerMoveEvent.POST_MOVE, can you share the code snippet, which interface to implement and method to call like notifyVetoableMultiObjectEvent. Thanks
