How to use alias attribut in drawing / part?
Hi there,
I want to display a "released by" information on my drawing.
I created an alias attribute with this mapping:
roleBObject@wt.maturity.PromotionTarget~roleAObject^wt.maturity.PromotionNotice~primaryBusinessObject@wt.workflow.work.WorkItem~theWorkItemReference@wt.workflow.engine.WfVotingEventAudit~userRef^wt.org.WTPrincipal~name=name@wt.org.WTUser~fullName
The attribute works great so far and lists all User's Full Names, which were involved in the process.
The attribute should be shown as parameter "released_by_alias".
But in Creo no such parameter is listed.
What am I missing?
TomU
TomUAnswer
Adding to what @HelesicPetr wrote, see this from CS248702:
joe_morton
I think you would need to add this as a new attribute in Creo, and probably make it part of your template files. You should also mark it as "designated".
HelesicPetr
Hi @Mat
It does not work that way as you think.
Calculated attribute is not populated to the drawing/model in creo automatically. It is not IBA attribute.
The calculated attribute value is processed when it is shown on Windchill page.
So in the Windchill it works perfectly everyone can see it but if you need it inside of drawing, you need normal IBA attribute and designated attribute in the creo drawing.
Also you need some code to propagate the value from workflow to the drawing without checkout/in. after that the drawing revisualization is needed .
Hope this information can help you.
PetrH
TomU
TomU23-Emerald IVAnswer
Mat16-PearlAuthor
@TomU  and @HelesicPetr , Thanks for Your answers.
@PTC: why, just why can't You provide this information like lifecycle state ( PTC_WM_LIFECYCLE_STATE ), Version  ( PTC_WM_VERSION ) or "modified by" ( PTC_WM_MODIFIED_BY )?
To me, it is another basic feature missing in this overpriced software suite.
But thanks god, that there is now an IOT interface.
18-Opal
@Mat ,
What you are trying to do can be done but as has been mentioned not with an alias attribute.
You are on the right track however to use the results of the voting to get the user's name.
You can add code to your workflow that gets the user's name from the voting immediately after the vote occurs and then have this name pumped into the value of the CAD Doc Drawing's Windchill String attribute "RELEASED_BY_ALIAS" (or whatever you want to call it).  Your CAD Drawing just needs to have the same designated String parameter "RELEASED_BY_ALIAS".
This creating/updating of the Windchill attribute can be done without iterating the CAD Doc if so desired.
As @HelesicPetr mentioned, it's unrealistic to think PTC will think of and implement every customization all of us can think of.  Part of our job is to fill these voids on a case-by-case, as needed basis. That's the way I've always look at this as it's realistic.  Plus, writing customization is fun. 😁
Mat16-PearlAuthor
I was able to get a working solution for my problem, which I had at the first place ( displaying "approved by" on a drawing).
I posted my solution here:
https://community.ptc.com/t5/Windchill-Customization/Info-How-to-set-attribute-for-quot-released-by-quot-quot/m-p/988177
