May 6, 2016 8:27 PM UTC
Suggest Text Box on IBA
I have a requirement to implement the suggestion text box on an attribute/IBA during Create wizard which would query all my suppliers from DB. I am able to make it work but I am not able to persist the value after selecting from suggestion list.
Any thoughts/samples ?
May 10, 2016 7:11 AM UTC
Hi Mahesh,
You will have to write a custom form processor, please refer to Windchill customization guide.
When ever a user updates the Form object like text box, selection box in Windchill, NmCommandBean is the place where you can find the value being reflected, to find the exact parameter name, you will have to debug in eclipse and the same could be persisted in custom form processor.
thanks,
Aditya
mgupta-21-VisitorAuthor
May 10, 2016 1:39 PM UTC
Thanks... let me try that now..
May 13, 2016 2:21 PM UTC
This is solved by OOTB logic, does not need an custom form processor..
May 15, 2016 7:19 PM UTC
Did you find any solution? If not, please share your code so we can help you better. It should work without a form processor.
May 16, 2016 1:55 PM UTC
Yes I did.. There is no need to write a custom form processor..
Thanks for your suggestion...
Jan 31, 2020 7:50 AM UTC
Can you provide an example please ?
