Feb 17, 2024 5:42 PM UTC
What stack is Windchill running?
What stack does Winchill run on?
I've always assumed Struts and Spring but not really sure.
tarik_perc
May 19, 2024 12:21 AM UTC
Windchill is using many third-parties in addition to its specific apis
I’m excluding rest and info engine from this answer
If you would like to know the Stack so that you learn them before you start working with windchill as a developer that would be very good from pedagogical perspective
Windchill is using spring MVC for its Client Architecture (UIs where JCADebug works)
+ Windchill is using its own Persistence Framework
To customize the client architecture, you must have knowledge of Java, jsp, expression language, jstl, spring core and spring mvc, then understand how windchill is using them since the client architecture is built on-top of these technologies
You will deal often with the client architecture as a developer, for domain classes you will deal with the persistence framework
Events and listeners use multiple and complex patterns such as observer, transaction, etc
Spring core is not used in services, instead Windchill has its own service delegate mechanism (the mapping between interfaces and implementations)
A good knowledge of RMI is also required in some cases, plus the client data model for business reporting and persistence apis
Windchill introspection mechanism but you will not touch it in most cases
I believe the complexity come from the enterprise abstraction which is hard to understand
jbailey
18-Opal
Feb 17, 2024 8:40 PM UTC
Java / Tomcat
Mar 15, 2024 3:07 PM UTC
It's mostly just core Java and Tomcat plus some Spring usage.
tarik_perc
tarik_perc
Jul 27, 2024 12:31 AM UTC
@NT_10748259 can you just trust me and close this thread?
Emeritus
May 23, 2024 3:37 AM UTC
Hello @NT_10748259,
It looks like you have some responses from some community members. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Community Moderation Team.
