How to Install Windchill Bulk Migrator on Target and Client Machine by using PSI ?
  • October 12, 2017
  • 2533 views
Hi All,
I am Trying to install WBM on target i.e. Windchill 11 machine, when i try to install it by using PSI, the WBM is not detected even i placed it in staging area.
also i am not able to locate setup.exe file in downloaded media for WBM.
 i have gone through WBM installation guide, but not found information about very first step of installation.
or is any other method of installation without PSI.
Kindly help me to explore the WBM.
here is snap of WBM media folders.
WBM media folders, no setup.exe found hereWBM media folders, no setup.exe found here
Vivek
vuchekar1-VisitorAuthor
Hi Windchillers,
Please help me here to install WBM on Client and Target servers.
Vivek
Hello Granite,
I am trying to install WBM but my PSI is not able to detect "PTC Windchill 11.0 Bulk Migrator -M030"installables  from staging area.
Do you get the solution of this ?
Were you guys able to find a resolution for this issue?
