Jan 6, 2015 9:15 AM UTC
Java Error!
Can somebody help me howto fix this? I'm using java 8 update 25.
Thanks in advance!!
Jan 6, 2015 9:58 AM UTC
First, befor installing new Java, You must clean cache of java app.
Start -> JAVA-> Java Control Panel -> General- >Setings -> Delete Files ...-> All check box -> Ok
After install Java 7 in Control Panel disable "Auto Update".
I recomed Use IE 10-11 or Firefox >30
Jan 6, 2015 9:22 AM UTC
You mast use Java plugin Version 7 update 60 (Get from Windchill10.2M022SoftwareMatrices081114.pdf)
Java 8 not support.
Luar1-VisitorAuthor
Jan 6, 2015 9:40 AM UTC
I tried to uninstall the version 8 and install the version that you said but it prompt me to install plugin and update the latest version of java.
