Using the environment variable In the custom menu
  • January 19, 2021
  • 5100 views
Hello community,
In the custom menu , i want to use the environment variable %JAVA_HOME% may also to be use lax.nl.env.path variable. Could you please tell me How to call that from the "Customize User Button" windows?
Windchill RV&S 12.3.1
Any tips well be very welcome
Zeiad
Best answer by IvyZhuang
Hi Zeiad,
Environment variable cannot be used in "Customize User Button".
You can refer to CS175170 for the details.
Ivy
IvyZhuang17-PeridotAnswer
Hi Zeiad,
Ivy
Hi @IvyZhuang
Thanks for your reply.
I was hoping that we could use .
Zeiad
Hi Zeiad,
I am using this script behind a custom command ("wscript runReport.vbs")
runReport.vbs:
Set WshShell = CreateObject("WScript.Shell")
cmds=WshShell.RUN("im runreport --hostname=%MKSSI_HOST% --user=%MKSSI_USER% --port=%MKSSI_PORT% --issues=%MKSSI_ISSUE0% --param=username=%MKSSI_USER% -g """&WScript.Arguments(0)&"""", 0, False)
Set WshShell = Nothing
And yes, I  am using environment variables.
Does this help somehow?
