Dec 17, 2014 8:21 PM UTC
Add a Custom Attribute to a specific task in Workflow
Is there an easy way to add a custom attribute only to a specific task in a workflow? For example, in the OOTB Change Notice workflow there is an Audit task. How would I add an attribute to this task only?
-Ryan
Dec 30, 2014 6:46 PM UTC
ok then change the set statement to
obj.set("IFRQ_Number", IFRQ_Number);
Dec 18, 2014 3:27 PM UTC
You can create variable in Task:
rhermann1-VisitorAuthor
Dec 18, 2014 3:30 PM UTC
Awesome. I actually got this far on my own. Next I want to take that variable information and map it back into an attribute on the change notice that way it is visible on the details of the change.
Any idea what the code for this is?
Dec 30, 2014 6:09 PM UTC
Thanks for the help. I dropped that code in my expression robot and hit check syntax and got the following (see image) im not sure how to fix it:
