Error installing Windchill
  • January 25, 2024
  • 2 replies
  • 1533 views
When I run Windchill I get this Java error
jbailey
18-Opal
January 25, 2024
What version of Java? What file are you trying to launch to install?
On windows, typically, ensure you have a proper version of Java installed... Open a command prompt as admin, navigate to the PSI install folder ... XX-0-X-0_PTC-Solution-Installer and run setup.vbs
