Proxy error on Export of large XLSX file
  • May 13, 2022
  • 3 replies
  • 1919 views
Receiving the following error when exporting a particularly large report to XLSX.The error comes consistently at 60 seconds. Is there a timeout option for Apache that can be increased? Using a reverse proxy.
Proxy Error. The proxy server received an invalid response from an upstream server. The proxy server could not handle the request. Reason: Error reading from remote server.
Best answer by SWeiler_9940261
It seems that the error was from Proxy Pass settings.
I added connectiontimeout and timeout settings into my ProxyPass:
G:\httpproxy\conf\conf.d\30-windchill.conf
As per suggestion in the answer from:
https://serverfault.com/questions/1014537/how-to-fix-apache2-proxy-httperror-ah01102-error-reading-status-line-from-re
That allowed me to exceed the default 60 second timeout.
Similar error in the following articles:
SWeiler_994026116-PearlAuthorAnswer
Glad you solved your problem!
