3-Newcomer
April 13, 2023
Self Signed wildcard certificate using keytool
  • April 13, 2023
  • 2 replies
  • 3461 views
Hello All,
I would like to know how we can generate the Self Signed Wildcard certificate using the keytool utility? If not possible through keytool, is there any other way using which we can generate the Self signed Wildcard certificate?
Avinash
HelesicPetr
3-Newcomer
April 13, 2023
Hi @HelesicPetr
Thanks for your reply.
From the shared Article and as per below snapshot, do we need to enter domain details in First and Last name?
e.g., CN=*.abc.com
Avinash
HelesicPetr
If you generate certificate for some address you need to define full address.
So yes you also need to use domain address
PetrH
jbailey
18-Opal
April 20, 2023
