Stop user from adding self to Setup Participant role
  • December 14, 2021
  • 3811 views
Does anyone have simple code that can go in the Transitions portion that will stop the activity to be completed if a user selects themselves as an approver for a role?  I have a simple workflow but I do not want users choosing themselves as the checker of the work.  Currently I am on Windchill 11.1.  A quick search didn't turn up anything on this subject, but I thought that there have been previous posts.
Best answer by HelesicPetr
This code will work >D
Change name of role as you need
this example use "APPROVER" as checked role.
wt.workflow.engine.WfProcess wfprocess = (((wt.workflow.work.WfAssignedActivity) self.getObject()).getParentProcess());
java.util.Enumeration roles = wfprocess.getRoles();
while (roles.hasMoreElements())
wt.project.Role role = (wt.project.Role) roles.nextElement();
java.util.Enumeration participants = wfprocess.getPrincipals(role);
// kontrola zobrazovaného názvu role
if (role.getDisplay().equalsIgnoreCase("APPROVER"))
wt.org.WTPrincipal activeUser = wt.session.SessionHelper.getPrincipal();
if (!participants.hasMoreElements())
String msg = "Approver MUST be assigned";
java.lang.Exception exp = new java.lang.Exception(msg);
throw exp;
while (participants.hasMoreElements())
wt.org.WTPrincipalReference principal = (wt.org.WTPrincipalReference)participants.nextElement();
wt.org.WTPrincipal assignedUser = principal.getPrincipal();
if (assignedUser.getName().equals(activeUser.getName()))
String msg = "Can not set yorself as Approver.";
throw exp;
 PetrH
HelesicPetr
throw exp;
throw exp;
 PetrH
Hello @HelesicPetr
I replaced my role in your code and then placed it in my transition and it doesn't catch anything. I don't know if it is because of having multiple roles to check against or not. Any suggestions would be helpful. I am going to try and see if I can get it in my current code that works with multi-role object catching.
HelesicPetr
Hello @BrianToussaint ,
I would check a log if there is an error from a workflow.
If there are more roles it's ok.
the while loop checks all the roles in the workflow.
 the if condition needs to be updated if you need to check more roles.
if (role.getDisplay().equalsIgnoreCase("APPROVER")|| role.getDisplay().equalsIgnoreCase("REVIEWER"))
Best Regards.
PetrH
