Thumbnail color - drawing images
  • August 19, 2016
  • 6658 views
Background:
During check in, thumbnails are generated for both models and drawings, so far so good.
I use a mapkey to use only the custom check in routine with both models and viewable objects.
What I would like to control is how the thumbnail drawing images are generated.  I don't have any issues with the model.
Issue:
When I use a blue background and check in, I get this in Windchill, both large and small thumbnails:
This is not so legible.  It opens in Creo View like this also and is very difficult to read.
When I change to a white background:
This works and is legible in WC and Creo View.
So the question:
How do I configure the monochrome thumbnail creation without having users change or force to B/W background?
Best answer by TomU
Thumbnail generation can ben enabled in the recipe file on the cad worker and optionally on the local Creo installation.  If enabled, Creo will generate the thumbnail during representation creation.  If not enabled, then the server's thumbnail generator will create the thumbnail after check in.  Either way, the thumbnail is derived from the created representation.  This means what you see in Creo View should match what you see in the thumbnail (except the background color which can be controlled independently.)
Conclusion:  You need the system colors to be consistent during representation creation (Creo View file, PDF, etc.).  Either the users need to work with the same system colors file or you need to switch to publishing on the server side.
Hi Ron,
I think you can set the background colour of thumbnails generated by WVS by setting a property in the wvs.properties.xconf file..
thumbnail.generator.backcolor
Default Value: 255,255,255
Synopsis: Sets the image background color for thumbnail generator.
Description: Specifies the image background color to be created by the thumbnail generator. The three numbers represent red, green, and blue in the range 0 to 255.
I have 2 CAD systems that want different settings, black for AutoCAD, white for CATIA /?
I don't think Windchill is generating the thumbnails in this case.  I think Creo is creating them before check in...
So a follow up.
I have shown Tom's Item 1 above.
I played around with item 2 to discover the true meaning, this is it pictorially to document it.
Within windchill, I searched for a part, selecting a drawing file that does not have an image
worth noting, in the second step (thumbnail window) the icon I chose was not an "open in creo view" selection but to create a rep.
The progression lead to a series of opening links.  the final result after a period of time:
shows there is a failure somewhere, at least thru this method within our setup (so this door nail is thinking!)
the previous image shows there were successful jobs and these images do appear in WC and they were generated thru CP via the check in routine.
So it seems Tom, you are on the right track but now I am entering a really dark tunnel....
