Using Eclipse
Documentation 10_MR040_WindchillCustomizationGuide.pdf on page 51 it shows project cust_Windchill_src in Eclipse. In order to load that project in you must follow directions from ant -f bin/tools.xml eclipse_project.help I followed these directions. Step 1) Run the eclipse_project task is too vague. I can get the cust_Windchill_src folder into the project window of Eclipse, but I have no supporting libraries or src folders. Can anyone explain what "run the eclipse_project task" actually means? I put in Filesync, but I am not sure it is working. Thanks.
