Nov 30, 2023 8:48 AM UTC
how to get object's creator in DataUtility?
I am trying to get objects creator in data utility. How to get Creator of Action item in DataUtilty which extends ActionItemDataUtility.
HelesicPetr
Nov 30, 2023 11:03 AM UTC
Hi @HO_10736653
In the dataUtility there is method getDataValue with three variables
The second variable Object var2 is your object that is part of the row
You need to retype this object to your object type where you can use object.getCreator()
example
WTPrincipalReference principa = wtp.getCreator();
PetrH
HelesicPetr
Hi @HO_10736653
example
PetrH
Nov 30, 2023 11:20 AM UTC
Hi @HelesicPetr , Getting below error at typeCasting to DiscreteActionItem object type:
ERROR : com.ptc.core.components.beans.DataUtilityBean testuser1 - CaughtException while processing column: itemDueDate. Enable 'com.ptc.core.components.beans.DataUtilityBean' logger for full stack trace.class com.ptc.core.meta.type.common.impl.DefaultTypeInstance cannot be cast to class wt.meeting.actionitem.DiscreteActionItem (com.ptc.core.meta.type.common.impl.DefaultTypeInstance and wt.meeting.actionitem.DiscreteActionItem are in unnamed module of loader 'app')
Code I am trying :
public class ActionItemDueDateDataUtility extends ActionItemDataUtility{
private static final String CLASSNAME = ActionItemDueDateDataUtility.class.getName();
private static final Logger logger = LogR.getLogger(CLASSNAME);
@Override
public Object getDataValue(String comp_id, Object datum, ModelContext modelcontext) throws WTException {
Object returnValue = super.getDataValue(comp_id, datum, modelcontext);
boolean isEditMode = modelcontext.getDescriptorMode().equals(ComponentMode.EDIT);
logger.debug("EDIT MODE :" + isEditMode);
//Get Current Action Item
DiscreteActionItem issueLog = (DiscreteActionItem) datum;
//Get Current User
WTUser user = (WTUser) SessionHelper.getPrincipal();
//Get Creator of action Item
WTUser issueCreator = (WTUser) issueLog.getCreator().getPrincipal();
if ( isEditMode && issueLog instanceof DiscreteActionItem) {
if(user!=issueCreator)
DateInputComponent returnValue1 = (DateInputComponent) returnValue;
returnValue1.setEditable(false);
return returnValue1;
return returnValue;
HelesicPetr
Nov 30, 2023 12:24 PM UTC
Hi @HO_10736653
In your case the object is not DiscreteActionItem .
I advice you to use a debug stop (eclipse and others ide support it) and check what type is there and how you can work with it.
From the error the original type is DefaultTypeInstance so you need to cast the object to this type
I also advice you to use if statement with instanceof to avoid that errors.
PetrH
