22-Sapphire I
March 14, 2017
qml report - Formats where referenced (drawings)
I may have posted this before - don't recall.  Haven't been able to get help from PTC tech support.
Would like to have a simple report that shows for an input list of formats (.frm), all the drawings which reference the format.  This is exactly what is displayed for a Format object on the Related Objects tab, Referenced By table.  Note: From this table, there is no export list to file, which is the main reason we'd like to have this report..
Seems like it would be very simple but I haven't figured it out yet.
thanks in advance
Mike - didn't this do the trick? - qml for Drawing >> related objects, Format
22-Sapphire I
March 15, 2017
There are quite a few .qml's attached to this thread - and I might have gotten mixed up but so far, not working.  If it seems to work for you (specifically for a given Format, find the Drawings which reference it), would you mind adding in such a way that I get it for sure?  Also would really appreciate a screen shot of it in use as noted - user fills in Format CAD Doc Number, report returns Drawings which reference.
thanks!
Mike
See attached qml...
Tuned a bit for your specific requirements but the report objects and links are the same
