Oct 15, 2026 8:17 AM UTC
10.2 MCP Server Unreachable
Before upgrading to 10.2 the MCP server was reachable by default at
https://mydomain.com/Thingworx/mcp
now after upgrading to 10.2 it returns HTTP status 400 - Bad Request.
Is there anything needed to be done during configuration/installation for 10.2 that could have been missed? Thank you.
smainenteAnswer
Oct 16, 2026 10:33 AM UTC
In 10.2, MCP endpoints are defined using a new entity type called MCP Namespace. Refer to :  Getting Started with Your First MCP Namespace
MCP was a preview feature in 10.1. Tare not migrated during an upgrade to 10.2.0 and are not available after the upgrade. You must recreate these assets by using the MCP Namespace entity.
Please note that the MCP Namespace URL format is now : /Thingworx/mcp/<MY_MCP_NAMESPACE>
An HTTP 400 response is typically returned when the MCP Namespace is missing from the URL. The response body should provide a explicit error message.
I also noticed that the Sample Use Cases section does not clearly mention the updated URL format. I will open a Jira ticket to have the documentation clarified.
Support
Oct 15, 2026 6:50 PM UTC
Hi ​@BS_12822535.
A case will be needed for this issue as it will require someone to dig into what is going on.  I couldn’t find a support account for you, but if someone else in your organization has one, we can open a case under their credentials.  You will need to private message me the information--I’m happy to open the case.
--Sharon
smainente16-PearlAnswer
Oct 16, 2026 12:16 PM UTC
This was the solution. Thank you for your help.
Oct 16, 2026 12:35 PM UTC
Thanks you for the update.
The documentation actually mention that the MCP resource is not migrated:
MCP
