8.5 date time picker clearing
I am using ThingWorx 8.5. The date time picker has a into mark to clear the selected date, on click of which returns 'Invalid date'. But, I wanted to clear the selected date time when clicking of that into mark. There is no clear property for date time picker. Is it possible to do?
Shalini V.
raluca_edu
Could you add an image to explain what you want to achieve? The date time picker widget has a "x" button to clear date.
Raluca Edu
Support
Hi @svisveswaraiya_285988.
Have you been able to solve your issue?  If so, please post the solution for the benefit of others on the community, and mark it as the Accepted Solution.  If Raluca's previous response lead you to find a solution, please mark that as the Accepted Solution.
--Sharon
