11-Garnet
Sep 7, 2023 2:34 PM UTC
9.4.1 new Grid Widget gone
After installing 9.4.1, I opened a large project in a web browser and none of the grids were showing in the mashups. After opening a mashup in composer, I saw this Warning (pic1), and where the Grid Widget should have been, was now blank, and the new Grid Widget does not show in Widgets (pic2).
pic1:
pic1pic1
pic2:
pic2pic2
I checked the release documentation before the install of 9.4.1, and as expected for a new widget introduced in ThingWorx 9, there was not mention of it being removed. When I found this odd issue after the install, I opened a case with PTC Tech Support, have not received  any help yet...
I used “MED-61212-CD-094_SP1_ThingWorx-Foundation-Installer-mssql-windows-9-4-1.zip” for the install, if not already done, that should be removed as a download option?
Is there a way to manually add the new Grid Widget?
JT_OU812Answer
11-Garnet
Sep 7, 2023 4:12 PM UTC
After contact from tech support, I did a full restart of the server, and now relievedly, I do see that widget, and the mashups show those grids. On previous Twx 9 installs I did not need to do a server restart. My Grid Widget issue is resolved.
JT_OU81211-GarnetAuthorAnswer
11-Garnet
