A design problem of FileTransferSubsystem
I have tried to call Copy({ async: true, queueable: true, ... }) 13 times, and there were ONLY 10 files copied. I have figured out that there is a setting called maxOfflineQueuePerThingSize. That's fine. The problem is, GetQueuedTransferJobCountByThing() does not return a number of jobs queued when the Copy above is called => I would be unable to check when I should not queue more Copy tasks.
My Bests,
Hung Tran
Support
Hi @htran-21.
Which version of ThingWorx are you running?
--Sharon
htran-2115-MoonstoneAuthor
Hi Sharon,
It is 7.4.19-b262
My Bests,
Hung Tran
22-Sapphire I
Do the other services like GetQueuedTransferJobs or GetQueuedTransferJobCount give you different counts?
vs. the by Thing?
These services are available in the FileTransfer Subsystem
