Abnormal Mashup Behavior on iPad
I'm having the same issue, but on IPhone using chrome.
I'm having this issue not on the button widget but on the navigation widget. I don't know a quick workaround for this problem. Is there a solution?
Jasper
Jasper,
One of our more advanced TW developers found a way to control button functionality through the use of jQuery and the Expression widget. If you add the below jQuery and reference the correct button ID, you can alter how it works on the client side. Something else this developer found was that using a Value Display as the "button" (it has a Click event) was easier as it doesn't have Hover event to work around. If using the Value Display Click, then no expression is needed.
$('[id*=button-32]').on('touchstart mouseenter focus', function(e) {e.stopImmediatePropagation(); $('[id*=button-32]').trigger('Clicked'); });
Let me know if this helps, or if you have found any other ways around the issue.
I'll post this same message to the Community board.
I was not able to jump to the link in your comment. It seems like linking to this same thread.
>>the same issue
What is the issue?
Support
February 1, 2019
Hi @tkawasaki.
I have fixed the link in the original post.
Apologies for the issue.
--Sharon
Jasper,
Bmehringer,
Thanks for the followup.
To the other people with questions about this, if the solution given by Bmehringer also works for you, please mark this as solution found.
Thanks again,
-- Craig A.
